enter image description hereenter image description here
I am having trouble wiring wiring this Nutone roomside dc series 110 vent fan! Any help would be greatly appreciated.
  • We need to know what "1" "2" and "3" are in the ceiling. I presume a fan was already there? Can you tell us precisely what 1 2 3 were connected to or if each has HOT and NEUTRAL on each? – noybman Oct 20 '19 at 22:42
  • They are each a set of black and white wires with a bare ground wire – Brittany Caramanna Oct 20 '19 at 22:52
  • Added new picture for clarification – Brittany Caramanna Oct 20 '19 at 22:57
  • Yellow marker indicates white wire – Brittany Caramanna Oct 20 '19 at 22:57
  • We really need to know either a.) Precisely how they were connected to whatever they were connected to (wirenuts and all) (or) b.) what each one is doing or will do. Example...one or all of them may be HOT to the panel (probably not), or, all three are coming from three different switches, or two come from switches, one is hot, or one gives power to a light.... ETC. Do you have a Meter/Tester and are you comfortable testing it? If not, you should call a pro. – noybman Oct 20 '19 at 22:58
