I tried to swap out a 70W 240V incandescent bulb with a dimmable 8.8W 220-240V LED. The switch is a dimmer switch, which probably has an old leading edge driver (the building is old).
This mostly worked fine; the bulb switches on to full brightness and can be dimmed (though not especially dim). However after leaving the bulb on for some time, it refused to switch off. The bulb would dim down to almost off, strobe at about 2-3Hz at low brightness for a couple of seconds, then switch back on to full brightness. After trying a few times, I have swapped it back to the old bulb.
On another circuit with the same type of dimmer, I swapped out a cluster of 3× 50W incandescent bulbs for 3× 4.7W dimmable LEDs with no (apparent) problems.
The dimmer switch is an unusual type which I haven't been able to find online:
dimmer switch with black dot in centre
The black dot in the middle seems to be a rolling ball (the rest is immobile). It functions such that tapping acts as an on/off switch, while "swiping" a finger up or down changes the brightness. Even before trying an LED it sometimes behaved oddly (e.g. gradually switching on then immediately gradually switching off with no further interaction).
From what I have read, it seems that the new bulb is probably below the minimum wattage for the dimmer, but I'm trying to understand why it switches back to full brightness.
Will I need to get the dimmers replaced to make this work? Would a slightly higher wattage LED work fine?
This is the dimmer malfunctioning. Simple as that.
This type of problem can usually be managed in one of two ways.
  • have one of the bulbs be incandescent
  • have a properly safety-listed "resistor block" (read: capacitor assembly) wired in parallel with the lamps. This mimicks an incandescent bulb in the way we aim to accomplish above, and uses less power, and doesn't burn out. In the States there's one I'm fond of recommending, made by Lutron and UL-listed, but it's not going to work in the land of square light switches. Consult your major dimmer vendors' catalogs if they make a similar module.
Make sure it is be BSI-listed, TUV, ETL, CSA, UL, one of the proper testing labs who is recognized in your country (an increasing number are, due to trade treaties). Chimazon will cheerfully sell you dangerous rubbish with a CE or CCC label.
LEDs need a dimmer that is rated for LED’s thier current draw is so low old school dimmers usually have this problem. The on off function is probably capacitive “touch” the rolling ball is probably much like a mouse the ball drives the resistor (an encoder in mice).
