2-part epoxies mixed in the correct proportion are what is used on the interior of food cans, and in factory tanks which handle food grade materials.
- They cure quickly, because they don't need to interact with air or moisture to cure, which means they aren't curing slowly while air moves through the layer.
- Epoxies cure by interaction with each other, not air. This is why they can't ship epoxy in one can.
- They also don't rely on volatile reducers to remain liquid, so they aren't boiling off chemicals for days or weeks.
- The surface cures very hard, and so, isn't nearly as subject to spallation and mechanical wear as a soft "latex" paint might be.
However, this is above your local hardware store's pay grade, unless you want to try to wing it with their packs of 5-minute epoxy (pro tip: get the 12+ hour epoxy or you won't have nearly enough working time), or trusting their garage floor paint.
I would go for West System 105 epoxy, myself, and if you do any kind of woodworking or fabrication work, it's rather nice to have in the shop for anything from fiberglass to glulam to bondo.
