I need to install a door but the tile is off by 1" from the top to the bottom? Is there an easy workaround for this?
thanks, Dean
Sign up to join this communityI need to install a door but the tile is off by 1" from the top to the bottom? Is there an easy workaround for this?
thanks, Dean
That is way out of plumb... but don't worry, there are solutions. You need a shower enclosure that has 2-piece side frames. They are designed so that the outer piece that the door(s) butt up against when closed can be adjusted by sliding them into a "U" shaped channel that attaches to the tile:
