Replacing my tub.
Below the tub is the PVC drain and it comes with a rubber gasket.
Then the tub-drain unit screws into the drain from inside the tub to make the connection.
I watched a video that said silicone was better than plumbers putty.
I've always used plumbers putty...Is silicone really better than plumbers putty?
I assume the silicone would never go on the PVC drain rubber gasket.
Do I still use Teflon tape on threads if using silicone?
Neither. The rubber gasket replaces both. Plumber's putty is mostly obsolete these days (almost everything comes with rubber or neoprene washers) and can stain fixtures, and silicone is never a good material for joining water-bearing plumbing components.
You could use PTFE tape as a secondary measure and a thread lubricant. Be sure to wrap it the correct direction.
I don't use the rubber seal that comes in the box, because it is usually thick and causes standing water.
They sell 2 types of plumber's putty: regular and a non-staining one. Old-school putty has been around for long time for a reason. It will dry out at some point; but rubber swells over time, so pick your poison.
  • You're using the gasket incorrectly. It belongs under the sink. Sometimes there's a second very thin one which would go on top, but that's going to compress to almost nothing.
    Nov 7, 2019 at 15:50
