How much caulking do we need to buy to caulk the rim of a standard 30" x 60" bathtub?
1If you need more than one then your tile guy sucked. – Mazura Oct 14 '19 at 20:34
One standard caulk tube will do a tub plus another.
plus
https://www.homedepot.com/p/HDX-smooth-rod-caulk-gun-10-oz-HD109/203788465
The caulk link above - my go to. The gun is just an example (that brand gun is actually crap and pushes out too much even when no pressure).
The way I caulk a tub is to run a first pass that goes as deep in as possible, hit it with a wet paper towel or sponge (push the caulk in), wait about a half hour, and then do the second coat and smooth the finish.
The tubes they have that you squeeze like tooth paste but larger, have not bought one of those but I see people pick them up all the time. – Ed Beal Oct 14 '19 at 18:14
2@EdBeal - Those are fine for touch up but for a new line I just can't see it. They don't have any uniformity of the pressure and the caulk would be everywhere. Also don't think one of the toothpaste tubes would do a tub. – DMoore Oct 14 '19 at 18:37
1@Mazura - if you wait it hardens a little and there is less movement under. Also if you wait you can clean up better from the first pass. I also try to grout the tub/tile line unless it is the supercheap plastic thin ones. Even if the grout cracks you can easily apply more. Applying a little grout every 2-3 years is a 10 min job, a recaulk is probably a couple hours. I don't think doing both passes on the caulk is bad - I just find it easier to wait. – DMoore Oct 16 '19 at 2:52
