My husband and I have a huge issue right now. Some guy messed up our tile job completely, so we are removing it all and replacing it ourselves (should have done it ourselves in the first place).
The tiles all popped up in whole pieces--the “contractor” did not back butter the tiles. Instead, he put all the thinset on the backer board that we just recently put down ourselves with screws (and taped and mortared the seams). Now all of the thinset is stuck to the backer board. We need to use this backer board again. How the heck do we take this stuff off? It’s really thick !! We’re talking about 320 sq ft....
Would it be okay if we sanded some of it down and then poured a self leveler over it?
Thank you!!
    FYI, no professional installer "back-butters" floor tile. That would be absurdly slow and is completely unnecessary. Something else went wrong here, like a bad mortar mix or incorrect product selection. Looking at the mortar pattern, either it was mixed too dry, left to sit too long, or the tiles simply weren't pressed in well. (A little squish and squirm is critical.)
    Oct 14, 2019 at 13:48
  • That doesn’t answer my question at all, and you are wrong about not having to back butter.
    – Rosemary
    Oct 14, 2019 at 13:54
  • It wasn't intended to answer your question (being a comment), and no, I'm not wrong. I built homes for several decades and have done many tile jobs myself. Never a single tile pop.
    Oct 14, 2019 at 13:56
    You don't have to back butter. You just need +80%. - "ANSI A108.5 section 2.5.3 states: “Average contact area shall be not less than 80% except on exterior or shower installation where contact area shall be 95% when not less than three tiles or tile assemblies are removed for inspection. The 80% or 95% coverage shall be sufficiently distributed to give full support of the tile.” – ceramictilefoundation.org - looking at the trowel marks still there, it wasn't +80%
    – Mazura
    Oct 16, 2019 at 2:38
    TBH, "we need to use this back board again" seems like a bit of an unreasonable requirement... It would probably cost more in time/labor (even DIY time has a cost) to try to salvage it than it would to replace it.
    Dec 20, 2023 at 14:13
6 Answers 6
For a small area, a grinder with a silicon carbide wheel will clean thinset off, but it is real messy. For your 320 sq ft area, it could be done, but I would be inclined to pull the backerboard up.
Was the backerboard thinset to underlayment plywood or something like that?
If height is not an issue, you might consider thinsetting new backerboard to the existing, after using a grinder to level out the high spots.
Sorry I cannot offer a more definitive solution; you are in a hard spot.
  • Thanks. Yes the backerboard is on the subfloor with thinset between. It would really pain us to take it off since we just put It down a few months ago. Put so many screws in each piece and even mortared the seams .... do you think a self leveling compound would be out of the question instead of putting more backer board ? I appreciate your help
    – Rosemary
    Oct 14, 2019 at 12:48
  • I would not rely on a self-leveling compound. Just my take, and I don't have engineering data to back it. I would level the existing thinset with a grinder to get a uniform height, and put new backerboard on. I would butter the two backerboards together, so that things are a firm sandwich.
    – mongo
    Oct 14, 2019 at 12:53
I would use a scraper like this (blade nearly perpendicular to floor). Pull rather than push.
Be sure not to repeat the mistake. Level and/or use larger notches.
I had this same issue when I replaced my kitchen ceramic tile with hardwood 20 yrs ago. I tried several products before finally finding one that works from Home Depot. I am truly sorry I can't recall the name/brand--but it did work well in dissolving the thinset. I took a grinder to the edges of a square-point shovel to make it sharp. Applied the product. Waited 20-30min. Then scraped up the thinset/mess with the shovel and a lot of elbow grease. The point is-- there is a product that will work. It may take a few tries to find it, but something out there does work. Grinding sounds like a LOT of work, a LOT of dust, and less than ideal (FLAT) results.
As to the back-buttering tiles question, I'll take isherwoods' word for it, but I have never seen a Pro that did not back butter tiles. It could be a regional thing?
  • peinal - are you taking about sulfuric acid? Its sometimes used to clean concrete off where it doesn't belong. But whoa, look out. I don't know if I would use it inside.
    – BrianK
    Oct 19, 2019 at 2:23
  • No. It wasn't sulfuric acid. Perhaps something like this: homedepot.com/p/ZEP-5-Gal-Heavy-Duty-Floor-Stripper-ZULFFS5G/… It has been too long for me to recall.
    – peinal
    Oct 21, 2019 at 17:49
Concrete disolver will work. But boiling water and let set a bit will make it much easier to remove. And yes floor leveling compound can be as thick as 2 inches in 1 pour. You would have to remove the thinset just to find the screws to remove backer board. Far as the back butter as long as you mix your thinset correctly and push tiles into the mix, it's way to slow to back butter especially floor tile. Just my way not right or wrong.
I used a heavy-duty floor scraper to take up the tile and thinset. Just use a shallow angle and it'll scrape off the thinset without digging into the backer board. You want something heavy with a really thick blade about 6-7" wide. Without being able to see it in person, I'm not sure if this is exactly what you want (I bought mine 20 years ago) but I think it's close.
-1
I am removing ceramic tile from cement backer board in front entry. I asked a young contractor installing my LVP the best way to remove the thinset. He borrowed my pry bar and lifted the edge of the backer board. “Take that out,” he said, “otherwise you’ll have crunching noises every time you step on the LVP.” It came out easily and I will replace with 1/2 inch plywood underlayment. Too easy!
  • "We need to use this backer board again." Also, putting tile over this is a very different situation than your LVP.
    Dec 19, 2023 at 20:23
  • Please take the tour to learn how we're different from a discussion forum.
    Dec 19, 2023 at 21:08
