I have hot water baseboard pipes running along the inside of the knee wall attic behind my second floor bedrooms. They are covered with old pipe foam sleeves. The knee wall is insulated as a conditioned space; rafters have faced batts.
To add extra insulation is it ok to cover the pipes with extra unfaced batts (r30) that i have from a recent attic insulation project? I just want to ensure that any heat doesn't escape from the pipes...
