A 10s video of my loud, squeaky treadmill operating is shown here.
As the video shows, it squeaks and makes a grinding sound, and it is much louder when a person is running on it. I have to wear earplugs to use it.
I bought it new only a year ago, the model is 'Sole F63 Treadmill'.
Any ideas on what I might try to fix it? It was a huge pain to put together but I would be willing to take it apart and try to fix since these things are expensive and I cannot buy another. Do you think a manageable fix might be possible, e.g. by oiling something in there or maybe replacing some bearing?
    Stop using it until it gets fixed. For instance, it could be a bad bearing and replacing a $5 part would fix it, but if its used with a bad bearing for a while, the axels or the hole the bearing presses into could be damaged which would be a much more involved and expensive fix.
    – JPhi1618
    Oct 10, 2019 at 15:16
You bought it new a year ago, and the manufacturer appears to have a decent warranty. Contact them. Any "taking it apart to fix it" is likely to interfere with the proper warranty process.
For reference, it's probably something wrong with the motor; you can confirm by using a cardboard tube or the like to focus on specific areas of the treadmill.
    Yes, their warranty is better than most. They came out and replaced parts on mine, even though the problem would not repeat while the tech was at my house.
    – Mattman944
    Oct 10, 2019 at 8:54
