I've been working with a local plumbing company on a few large bathroom projects and they've done some things really well and some things poorly, and on a few cases, I've jumped in to just make the fixes myself rather than deal with them. In this case, they did the shower pan liner, but as shown, they actually cut the sheet around the bolts. They also just GOBBED sealant all over, including filling the weep holes and channels. It didn't drain from them at all till I took it apart cleaned them - it drains very well now. However, I have concerns about whether or not it was sealed really well underneath or if it's a long term issue that's pending. I have to pull part of it down anyways since they didn't get it flush in the corners (!), so I'm wondering if it's worth spending the 50 bucks to just do it myself. It's an oatey drain.
I'm leaning towards just doing it again, but I don't know - does the rubber being cut so far back indicate an issue or am I being uptight?
Thanks.
  • This is not your shower... correct???
    – JACK
    Oct 9, 2019 at 23:07
  • This is our future shower, as the plumber left it, except I cleaned the weep holes. The brown stuff on the top of the clamp is where my dirty hands rubbed on the sealant. Tools are mine, from taking the clamp off to clean.
    – James F
    Oct 10, 2019 at 0:06
  • Personally I would tear out the liner entirely and redo it using kerdi board or similar.
    – Matthew
    Jul 6, 2020 at 6:14
Since it's going to be your own shower and there are a few things bugging you about it I think it's worth the 50 bucks to do it over and fix the things you are concerned with. If you don't, and you're anything like me, it will be nagging you forever that you didn't fix it. Enjoy your new shower either way.
    This might not apply, but if you "re-do" any of their work, they will not warranty anything. They will just say that since you meddled with their "fine craftsmanship", any problems must be your fault.
    – JPhi1618
    Oct 10, 2019 at 15:12
