This utility sink has a slow drip from the end of the spout. This should be easily fixed by replacing the rubber washers in the levers, however the phillips screws, shown further below, seem very tight. Would both screws loosen counter-clockwise, or would they be opposite? I was thinking of using a manual impact wrench (the kind you actually hit with a hammer) but I didn't want to break it in the wrong direction.
Update: I've removed the phillips screws, but now the part under the handle that I need to remove, indicated by the red arrow below (what's the name?) seems very stuck. Are these also both loosened counter-clockwise?
Bonus question: Sometimes the faucet leaks near the base of the spout (see red arrow below). Is that also fixed with a rubber seal replacement? Is that done by turning the hex ring near the arrow counter-clockwise? It's not easy to get a tool around it!
