I need to remove this metal conduit or at least bring it even with the floor. I don't need to worry about preserving the wires inside the conduit. I only have a little hacksaw, but I'm open to buying other tools if needed. What's the best way to get rid of this conduit so that it's even with or below the floor?
2I’d use an angle grinder with a metal cutting disk– KrisOct 8, 2019 at 2:20
1Possible duplicate of How can I cut a metal pipe while preserving the wires inside?– Solar MikeOct 8, 2019 at 2:37
1@SolarMike it's the same building site, but he's decided no to preserve the wires.– JasenOct 8, 2019 at 2:46
I don't think this is a dup.– Harper - Reinstate MonicaOct 8, 2019 at 3:23
1pull up the boards– jsotolaOct 8, 2019 at 5:35
I'm assuming you don't have access to the backside of this conduit. If you did, you would just disassemble it - find the nearest coupler, uncouple it, and remove the pipe.
Remember to remove these orphan wires entirely; all the way back to the previous junction box (or past it, if they go past it). You're not supposed to leave orphan wires, though.
I can't seem to pull the wires out no matter how hard I pull, but I have confirmed there's no power going through them. Is that good enough? I don't know how I would remove the wires completely. Oct 8, 2019 at 3:33
1@dfitzgerald You're pulling from the other box, right? You shouldn't pull from the pictured end. 2 wires shouldn't pull that hard out of 1/2" conduit, so if 10 pounds of pull doesn't do the job, there must be an intermediate box or conduit body somewhere. Again, Code requires it be accessible. Oct 8, 2019 at 3:42
A toner can help you track it through your walls since the conduit is metal. Oct 8, 2019 at 5:33
@dfitzgerald You show no power now. The concern is, what if the other end is not simply chopped off somewhere but switched off (breaker or a regular switch) and someone flips it back on, not knowing where it goes. If all goes well, either nothing happens or a breaker trips quickly. But if it doesn't go well, you end up with a fire. Oct 8, 2019 at 14:14
@FreshCodemonger Brilliant. Put the toner on the conduit... Oct 8, 2019 at 18:17
Try a reciprocating saw with a blade designed for metal. Big brand name is Sawzall but all the major tool companies have them.
They are available both corded and battery powered.
A dremel with a metal cutting wheel will work.
Yeah, that's exactly what I'd do under the circumstances. Oct 8, 2019 at 3:23
4.5" angle grinder. Pick one up at harbor freight for $15. They are so cheap I just keep 3 around with different thickness discs attached instead of fumbling to change them. If one dies you have spares.
The other tools - oscillating/reciprocating/dremel generally are going to be more expensive, slower, and harder to get a flush cut. While I tend to buy cheap grinders I don't recommend cheaping out on the other tools.
1Interesting use of cheap tools. That said, don't use cheap discs. Oct 8, 2019 at 18:17
