I was trying to install an Ecobee thermostat, and there was no C wire installed. When I went to install the power extender kit, I saw the standard C wire terminal was broken out of the black plastic casing, and I couldn't attach the C wire. There appears to be a secondary C terminal that is a different style with a plastic plug plugged into it, and then the wire is spliced and connected to the wire heading to the AC unit. Can I add a second wire to this plastic plug, is this a secondary C terminal that should work fine? I attached a pic.
Thank you!
  • Can you post a photo that shows the main terminal block square-on? Oct 7 '19 at 2:15
  • I added the pics I have on my phone - I am at work now, and can take better pics when I home tonight if needed.
    – Braden
    Oct 7 '19 at 14:09
That looks good to me, the second "C" terminal connects to the chassis in the background of the photo so it most likely is equivalent to the screw-down terminal.
fitting a crimp-on fork lug to the wire would be another alternative if you really want to connect to the screw-down terminal.
  • Thank you very much!
    – Braden
    Oct 7 '19 at 12:58
  • Just an update, I took off the wire nut, added the common wire from the Ecobee power extender kit, added a new wire nut that can handle four wires, and things are working perfect. Thanks again!
    – Braden
    Oct 8 '19 at 13:07
