Samsung dryer, model DV422EWHDWR/AA
My Dryer has a 3-prong cable, I need to upgrade to 4-prong.
I have TWO GREEN wires here, which is something I cannot find mentioned anywhere else. I reckon that one of these corresponds to the usual solid metal tab connecting the terminal assembly to the dryer’s metal body, and the other corresponds to the (usually white) connection that “pseudo-grounds” from the neutral connection, but I‘m uncertain, don’t want to die, and don’t want to destroy the dryer or the house.
I think I’m supposed to remove the smaller green wire, and connect both the white and the thicker green wire to the center connection on the terminal assembly.
Can anyone offer me wisdom in this matter? If this question is a duplicate, I cannot find any similar question especially regarding the ostensibly mislabelled and extra green wires.
(The image descriptions didn’t appear in the post like I thought - the first image is a picture of how the dryer cable was arranged before I did anything, the second image is of my preliminary tinkering, now I believe that thick green wire should connect to the center terminal with the white cable.)
