I recently bought a house with a gas fireplace. The house was built in 1997 in Texas. The fireplace damper is stuck open and I can't figure out how to fix it - I had a look and it doesn't appear to be rusted, which I've heard is the most common cause.
I have attached 2 photos - one where you can see the pole/pull attached (which I believe is the bottom of the damper) and the other which I think is the top of the damper. As far as I can tell there is a plate attached to the top of the damper which is getting stuck against a ridge/lip in the chimney. What surprised me is that it looks like maybe 1/4 of an inch worth of a lip that is blocking it - almost as if that plate was added to block it in the open position? There is also a strange clamp attached to that side, which I have no idea why it's there or if it should be there.
I haven't tried anything other than yanking down really hard on the pole/pull and also sticking my hands in there to try and push that plate past the lip. I don't want to try too much brute force since I don't have experience with this.
Any advice greatly appreciated.
Bottom of damper
Top of damper
That thing that looks like a weight held onto the damper by a long bolt? That's a damper clamp. When a fireplace has a damper, and is converted into a gas-burning fireplace, by code the damper must be fixed in a fully open state. Otherwise, if the damper were closed, and the gas turned on, you could get gas and/or carbon monoxide blowing into your house, either of which would make it likely you would Have A Bad Day. (This isn't required with wood fireplaces, as if you leave the damper closed then the gouts of smoke will make your mistake obvious.)
So, the solution? Leave it alone: it's possibly saving your life.
References:
  • This is very helpful information, thank you Daniel. I suspect the clamp isn't what's keeping it open (since you can see in the picture that it's not currently hitting anything but it's also not moving at all), but as you pointed out it's a moot point since it's better to have it open the whole time. Is there something folks usually do to prevent heat loss during the winter? I probably won't be using the fireplace for a few years since I have small kids, so I'm mostly just thinking about the extra (AC) heating cost during winter. Oct 6, 2019 at 18:08
  • You could install a chimney balloon, as long as you made it difficult to light the fireplace without noticing the draft was blocked. (I'm not sure how this works with code, though... anyone?) Oct 6, 2019 at 21:09
  • I figured that's the best approach - no idea on the code though. Thanks again Oct 7, 2019 at 21:07
