I have a non-working oscillation 3-speed fan. After some detective work, I found that both wires going into the start capacitor are hot. Is this what it should be?
There are three wires, maybe four (3 speed plus neutral), going into the motor coil and two wires coming out of it. These two wires go to each end of a capacitor. The capacitor is rated at 1.5 uF. I tested it and it was 1.2 uF. So, I bought a new one to replace it. After the replacement, the fan still wouldn't work. I checked the two wires and found that both were hot. I don't think this is what it should be, correct?
