Switching my lamps from fluorescent bulbs to LEDs (GR8 socket).
While dismantling the lamp, I accidentally pulled out the cord, as seen in the topmost picture, and I can't get it back. The other cord seems tight as well, and feels like a I have to brute force to pull it off, no?
I tried pushing the little plastic handle (advice I found online) on the other side, but apparently broke it. I'm not even sure if this is what should be done to get cords loose?
Can I still use this old GR8 socket to install the lamp or is it toast? I bought wire and new switch terminal, but GR8 sockets are rare and I would need to order them abroad.
  • you should be able to just shove the wire back in there.
    – JACK
    Oct 2 '19 at 19:40
  • It is possible the backstab will grab if trying to put back in, I thought the op was removing the wires. I would get a t-pin or hat pin and push the stab down this usually releases the wire
    Oct 2 '19 at 22:37
  • take the cover off ... the latch is seen in the second picture above your thumb
    – jsotola
    Oct 2 '19 at 23:04
  • Those little round holes there, any chance they have a slot in them for a screwdriver? Oct 3 '19 at 7:06
