I have a Kohler pop-up tub drain and the lift rod fell off the crank piece of the overflow hood assembly. What's the best approach to try and fish the rod, spring, etc., out? Obviously, I don't want to remove the tub.
Alternatively, can I replace with a toe stopper style drain stopper? For now, it's a $5 rubber stopper...
  • Hello, and welcome to Home Improvement. Would you add a picture of the situation? And, you should probably take our tour so you'll know how best to participate here. Commented Sep 30, 2019 at 1:56
    Have you tried a shop vac to see if you can suck it back up the drain.
    Commented Sep 30, 2019 at 21:52
These are cheap and a great addition to your toolbox.
Provided it’s long enough, this should get a grip on it.
enter image description here .
For $30, you can get a "camera on a stalk" (I have one from DEPSTECH that occasionally works) that will allow you to peer down into there. Many also come with magnets and little hooks to help retrieve lost pieces.
