enter image description hereI want see if someone help me on hooking up this new Honeywell thermostat with Wifi I just purchased. I have an old ac unit and I only have 3 connections to my circuit board which does not have an option to connect my wire. Any help would be appreciated. Thanksenter image description here
  • often C connects to the body of the air-condtioner. is there a wiring diagram on the inside of the cover? – Jasen Sep 30 '19 at 2:27
  • Disconnect R and measure voltage from R on the board to the body of the air conditioner - should be approx 24V AC – Jasen Sep 30 '19 at 2:37
  • Hello Jasen. Thanks for giving me some input. There is a wiring diagram on the cover. I will also test the R wire. I had seen another post where they connect to one of the blue wires that go to the body which I tried but my fuse blew out when I connected the thermostat and I made sure that all the wires we're connected properly. – Guillermo Avina Sep 30 '19 at 16:17
  • if you can add the wiring diagram to the question that will help. – Jasen Sep 30 '19 at 19:08
    @GuillermoAvina can you post a photo of the thermostat wiring at the thermostat end please? – ThreePhaseEel Oct 5 '19 at 14:30
TLDR: connect the c-wire to the chassis or to pin 6
Here is the link to the GMP075-4 Installation Manual
The manual has a diagram exactly similar to the picture you posted, which is good because it's the foundation of my explanation:
Notice the BL wire (the blue wire) attached to pin 6. This wire has two tell-tale signs of being your C-wire:
  • It is blue
  • It is connected straight to ground
Blue is a color usually reserved for the common wire. This has been a standard practice for a while now - I'm not sure when thermostat wire colors became standard, but it'll definitely apply to any units within the last 30 years.
The common wire's main function is to behave like a ground wire. Nothing in the system likely needs a grounded thermostat wire except for a newer thermostat. For current to flow through a device, there needs to be a difference in voltage between two wires connected to the device. In the case of your thermostat, it will see 24V on the red wire (red reserved for constant power), and 0V on the blue wire (0V means ground, or 'common'). Thus, there is a difference between 24V and 0V, so power can flow through the thermostat. This wouldn't be possible with any other wire (white, green, yellow) because they are not providing a voltage difference from the 24V red.
So based on the standardized practices of color codes, and based on the functionality of what a c-wire should be, pin 6 on the diagram is where you connect your c-wire. You could also connect it to the body of the blower if the blower is grounded (and it should be). If connecting it to the blower caused your fuse to pop, I suspect there's another issue at play, and you should most definitely check the AC voltage difference between the blower's chassis and pin 3 (the red wire). It should be 24V. Anything else and you may have a different problem.
| improve this answer | |
I think you've already figured out that older units often didn't run the C wire. Power from 'R' was switched to 'G' (fan) and/or 'W' (heat) by a simple switch in the thermostat. The older thermostats needed no power, so there wan't any point in running the common wire 'C'.
Older "smart" thermostats worked off the difference between 'R' and 'W' when the heat wasn't on, and then used batteries to ride through when it was on. That was fine before we wanted WiFi connected thermostats, but the new stuff wants more (and constant) power.
The wire labeled 'C' on the diagram is what you want. That gives the other end of the 24VAC transformer.
This site has great coverage of all this: https://smartthermostatguide.com/thermostat-c-wire-explained/
  • Problem is, connecting C from the t-stat to chassis blows a fuse on his unit... – ThreePhaseEel Oct 3 '19 at 4:07
