At the tiled wall surrounding the tub, at the bottom of the tiles where the tiles end and intersect the tub rim, should it be grouted ( epoxy grout)? or leave it open and caulk with silicone caulking? Please advise!
2This gap is usually caulked as are the inside corners. I use a caulk made for tub and tile that is not silicone. Silicone is difficult to make a smooth bead with and is problematic when re caulking is necessary. – Kris Sep 29 '19 at 23:06
tilecleaning.org/grout-vs-caulk-in-tile-shower.htm – Kris Sep 29 '19 at 23:25
Caulking always! Fill the tub 50% with water and caulk it. Allow the caulking to dry then drain the tub. If you caulk with no water in the tub poly, fiberglass and composite tubs stretch and tear the caulk when filled. Cast tubs are usually solid enough to not make a difference.
2Totally agree with Ed. Grout at that seam will definitely crack with the slightest settling, even the epoxy grout. – JACK Sep 29 '19 at 23:46
What is your opinion on caulking with silicone vs a siliconized acrylic caulk? I don’t think many homeowners have the skill level required to neatly tool silicone. And I prefer knowing I won’t have bonding issues when it’s time to redo. – Kris Sep 30 '19 at 0:19
3When they are water based and clean a wet finger is a great tool. I will only use tub &tile calking as it has mold inhibitors. The trick is getting the old stuff cleaned out first. With new tub surrounds I will use a 400 grit sandpaper inside the joint then wipe it down and calk the small scratches inside help the sealant hold, some of these surrounds look great because they have a slight coat of wax the sealer fills the void but falls out later, I once had a home owner swear I should be able to purchase this seal that fell out in one piece. – Ed Beal Sep 30 '19 at 0:34
At the tub I calk above the tub to tile. In the corner I grout above the tile line with the same grout used for the rest of the tile. – Ed Beal Sep 30 '19 at 21:30
Matching sanded or unsanded caulking is a must. 9/10 times you can purchase a caulk that matches the grout. By using the matching caulk, it creates a natural looking flow for all the tile and grout you just installed. I recommend what one of the other members suggested and fill the tub half way with water, then use matching caulk around tub, then drain. You’ll have a nice looking tiled shower/tub after
Most bathrooms I've been in seem to have silicone sealant in this area. I think this may be an evolution of tile grout (and other sealant types) which (used to?) be somewhat prone to developing black mould (or cracking, leaking etc), especially where there's a shower over the bath. Some silicone specifically claims to have anti-mould features, although water-fastness is probably its main defense (eg. https://www.amazon.co.uk/2079356-Anti-Mould-Silicone-Bathroom-Cartridge/dp/B01G3OCFVI).
In my own bathroom, the tiler fitted the tiles, with grout to the top of the bath tub. Then, they siliconed around the bath tub (with plenty of water in it at the time). They didn't use a particularly large bead of silicone though, and in some places it's insufficiently covered the gaps, and so there is a tiny bit of water ingress where silicone meets tiles. Over time, this goes black, which only seems 'solvable' by bleaching.
I believe the solution here would be to scalpel-cut out the existing silicone and replace with new (and use a slightly larger smoothing tool), whilst making sure that the silicone gets properly "pressed" into all the gaps between tub and tiles so that it adheres to all surfaces properly.
IMHO, silicone is both great and terrible. Using a smoothing tool (eg. https://www.diy.com/departments/diall-smoothing-sealant-tool/1642133_BQ.prd) is a must, as is wearing gloves and having a selection of rags and whatnot available for wiping up excess (which needs white spirit). You also don't seem to be able to buy silicone in small quantities (and you'll need a sealant gun too). For the professionals, I'm sure none of this is a concern, but for DIYers, it takes a bit of practice to get it right (and probably a fair bit of waste afterwards).
I always use a color match caulk on any right angle or edge of tile,silicone is not a good idea for too many reasons.
Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know how best to contribute here. – Daniel Griscom Sep 30 '19 at 21:47
I've started using DAP 3.0 caulk. Alcohol clean up and it REALY sticks well to all surfaces. Only in clear and white though.
1Hello, and welcome to Home Improvement. This is really a comment, not an answer. With a bit more rep, you will be able to post comments; in the meantime, please take our tour so you'll know how best to contribute here. – Daniel Griscom Sep 30 '19 at 12:21
I was always taught that you should use a flexible sealant at every change of direction or material.
So all intersections, angles etc. plus where tile meets another material such as the tub or a non tiled part of the wall etc.
Obviously sometimes this means you'll need a paintable sealant (tile to wood or plastered wall/ceiling for example).
I always use a high quality sanitary silicone between the tile and tub.
