My grill is: the Weber Q 1200
If an outdoor gas grill's push-button battery-operated igniter is making clicking sounds, but grill doesn't light, what clues does that give me?
I think it means that the module is mostly working, the battery is working, but somehow there's no flame produced. Is this correct?
Also: what's the first thing I should try to fix?
Update (how it was solved):
- the accepted answer was very helpful to me because it broke down for me that the most likely culprit was probably food drippings in the area where the igniter spark operates.
- So, I lifted the grating, scraped off any rust/drippings in that area, and my igniter started working again.
- There wasn't anything wrong with the igniter. It was just that the gas wasn't coming out of the nearest hole in the gas pipe because that hole was rusted over and blocked by food drippings.
