My refrigerator (Bosch B22CT80SNS01) sits in an alcove and has begun intermittently making a noise from what seems to be the inside. At first I thought it was the water filter/lines having air, but I’ve switched the filter and cycled water for a few minutes. Running the water doesn’t stop the noise when it’s happening either, nor does it sputter.
It sounds like it’s behind an inside panel at the top, maybe a fan or something? See video below.
https://imgur.com/a/KBlKLYH
  • The ice maker or maybe the defrost cycle?? – JACK Sep 29 '19 at 14:48
    I took off the grill where the noise was originating and the insulation components behind it. A little motor that opens a door to let cold air flow into the refrigerator from the freezer was making the racket. Looking it up online shows it's the "Refrigerator Air Damper Control Assembly" here. I think this is what I need to replace. – Untitledfolder Sep 29 '19 at 15:49
  • Those do frequently go bad so good job and good luck – JACK Sep 29 '19 at 15:53
It turns out it was the air damper motor and so replacing the assembly did the trick! No more noise.
    Hello, and welcome to Home Improvement. Thanks for answering your own question. You can click the checkmark next to your answer to indicate it's the "right" one. – Daniel Griscom Oct 2 '19 at 23:31
  • Done! Thanks for the tip! – Untitledfolder Oct 4 '19 at 0:05
