I have a Concrete Foundation Pillar that is 5/8th of an inch too short. What filler materials are appropriate when a steel I Beam will be resting on it? Can I use mortar, or is steel more appropriate?
mortar is not really structural, I would go with steel, perhaps half-inch plate and some washers
  • Why 1/2” plate and washers over a 5/8 steel plate? Commented Sep 27, 2019 at 23:08
  • sure, 5/8 if you can get it. or flat bar instead of plate.
    – Jasen
    Commented Sep 27, 2019 at 23:11
    Non-Shrink Structural Grout is an option. Really even wood in the correct orientation is fine. The crush strength of wood is quite high. Commented Sep 28, 2019 at 1:44
    @FreshCodemonger The appropriateness of wood for something like this can vary depending on conditions and the type of wood. You don't want your structural support rotting away, after all.
    – nick012000
    Commented Sep 28, 2019 at 9:00
