I had an electrician upgrade my old fuse electrical panel with a new breaker panel. I was trying to save a bit of money and decided I would build the external access door for the main shutoff. However, it seems to be a bigger challenge than I was anticipating.
From the picture you can see the bottom of the panel barely clears the framing stud that runs diagonal when you open it -- circled in red. I originally was just going to frame around the box and attach a door but now that the diagonal board is there I'm not sure what to do.
Does anyone have any suggestion on what I can do here?
