I realise that this may be an impossible question, but I was wondering if somebody would be able to help.
For the majority of traditional boiler setups in the UK where hot water is stored in a tank, what does the thermostat connected to the tank to control the temperature of the hot water look like? I'm totally blind, and it appears that there are lots of things that look like taps connected to my tank but I haven't/wouldn't want to touch anything until I was 100% sure that it was the right control. I realise that this may not be easy to answer, but something to get me on the right track would be very much appreciated.
  • Can you get us make/model info on the boiler? – ThreePhaseEel Sep 24 '19 at 23:54
A boiler cylinder thermostat is usually a small rectangular box, often with a temperature adjustment knob (which may be recessed for screwdriver adjustment), which is fixed to the side of the cylinder with a strap or cord going round the cylinder horizontally. Sometimes this is an elastic wire like net-curtain fixing wire. The insulation between the thermostat and the copper cylinder should be removed so the thermostat is in good contact with the cylinder metal. It will have an electric cable coming out of it to a junction box connecting to the boiler control circuits.
In some cylinders the thermostat will have a probe on the back and this will slide into a pocket in the cylinder to make good thermal contact.
If the thermal contact between the cylinder and the thermostat is poor, the boiler will not recognise the water getting hot enough and your hot water will be too hot.
The other thing(s) actually on the cylinder will be immersion heaters, and they will usually be at the very top or the very bottom of the cylinder, be fixed into bosses on the cylinder, and have a stiffer, thicker, electric cable to a switch on the wall.
The immersion heaters will have thermostats under the covers to control the water temp when using the immersion heater, but this won't affect using the boiler.
Older boiler installations often don't have a cylinder thermostat and rely on the boiler's internal thermostat to control heating and hot water temperature, which is wasteful.
Larger boxes connected to the pipes are likely to be zone valves to change-over between heating and hot water. They'll thunk when they operate, and will often have a manual override lever on the side.
| improve this answer | |
