Is there any study or calculation on how much money I save if I buy door/window X with a certain R value vs door/windows Y with a different R value?
I am afraid that this whole thing with better and better doors for which you pay more is just like with the electric cars, the cost difference offsets the savings
Please if you are aware of any article or webpage share it here, my google fu is letting me down, I could not find anything
It's a very straightforward calculation, though parts of the industry prefer to pretend otherwise. Also, math is involved, and that tends to scare off people with math scars from school. Dumbed down approaches give dumbed down, generalized answers.
First, establish if you are dealing with Metric or "English" (BTU based) R values. They are similar but the units are different. Since it seems likley that you are dealing in square ft and BTUs and that's what I do normally as well, I'll go that way. Also note that some items (windows, quite commonly) will be specified in U values, which are 1/R. Let a spreadsheet do the math.
Then add up the areas of your house that are various constructions at various R- values (which you'll have to figure out from looking at how they are constructed, if you don't know) - ie, 1200 square feet of attic at R50, 2400 feet of wall area at R-12 (or 2400 square feet - 42 square feet of doors and -100 square feet of windows) and 42 square feet of doors at R-4 or R10 or whatever you are comparing and 100 square feet of windows at r1 or R3 or r-5 or whatever you are comparing. Beware of "as-built .vs. insulation-only" R-values for things like walls, where having a wooden stud at R1-per inch every 16-24 inches really adds up over the whole house. Or, ignore the parts of the house OTHER than those you are considering options for, as those won't change until you change them.
1200 square feet of attic at R50 will require 1200/50 = 24 BTU per hour per degree F to heat.
2400-142 square feet of R12 wall will require 2258/12 = 188 BTU per hour per degree F to heat.
42 square feet of R2 door will require 21 BTU per hour per degree F to heat, while 42 square feet of R10 door will require 4.2 BTU/hr/F
100 square feet of R1 window will require 100 BTU/Hr/F and R10 window will take 10, while R3 window will take 33.3
Now, look up the annual heating degree days for your area, and you have some number (say 6000) of days * degrees for a typical heating season. Multiply THAT by 24 hours per day and you know the seasonal load for each part of your house - 6000*24*100 = 14,400,000 BTUs for 100 square feet of R1 windows, 4,800,000 for R3 windows.
Now follow that down the "how you get your heat and what that costs" path (btu per unit of fuel, efficency of how that's converted to heat delivered to the house) to sort out the annual operating cost difference for the options you are considering. Then consider the lifetime of your windows, and likely trends in fuel costs. For electric resistance heat, 100 square feet of R1 window in a 6000 HDD climate is 4,219.2 kWh/year; r3 is 1/3 that, R10 is 1/10 that.
For a more complete heat use modeling job you should also consider ventilation rate, but again, not that much of a factor if you are only looking at "this window .vs. that window." There are also models that attempt to account for solar gain from windows, but that is difficult to model well in a complex environment with shading, etc.
    This is like the calculation for sizing the furnace :-) which I was aware of. I was hopping for an "eyeball formula" – MiniMe Sep 23 '19 at 16:33
  • The windows/doors are, indeed, just a piece of this math, which is that math. – Ecnerwal Sep 23 '19 at 17:32
Look for roi on replacement windows and doors. Here is one such article
Also, “are high efficiency windows worth it” led me to this article. Also: energy.gov and an interesting story from NPR
  • Good links thanks a lot. However they do not really address exactly what I am asking. For example here they indicate the cost savings when replacing single pane and double pane windows with Energy star rated. energystar.gov/products/building_products/… My question is more like door X is $400 more than door Y because it has a better R value, it is just a bettewr material I guess , but how does that R diff translates into money? – MiniMe Sep 23 '19 at 13:59
  • @MiniMe there are a lot of variables involved and i’ve Not seen a website where you can plug in the number of windows and doors, their size, their type, your location, and your current energy use and cost to get an up or down on if it makes sense, if you are going to spend $400 more on a door, what are the energy efficiencies of them? Another consideration is the value added to the house. If the most efficient door is ugly, it is likely to cost you money on resale. – UnhandledExcepSean Sep 23 '19 at 14:07
  • In my case it is a patio sliding door and there is not a lot of variations in the artistic design of the door. I am looking at this door farleywindows.com/patio-door/the-9500-patio-door vs the Imagine one in this catalog yumpu.com/fr/document/read/60778602/… (page 8-9) First one is 500 CAD cheaper before taxes. Farley U 1.65, ER 36 Novatech U 1.76 ER 27 – MiniMe Sep 23 '19 at 14:20
Use this, or something like it:
http://energy-saving-calculator.inoutic.de/Default.html?ID=385&CountryCode=EN&LanguageCode=EN
I just found this formula while I was looking for something else
