I have a Craftsman 113.298031 tablesaw. Recently it has started making a whining sound and the blade is easily bogged down. Previously the blade bogged down without the noise and I had to tighten the belt. This seems different. I took the belt off and the motor seems to run well by itself. I suspect bearings on the blade assembly but haven't taken it apart yet. Any suggestions before I get started? Likely just lube? Might need new bearings? Thanks for anything you can do to shorten the repair process.
    how old is the blade? are the teeth loosing their "set"? shaft spinning and blade bogged down?
    – JACK
    Sep 22 '19 at 16:32
  • It's a fairly new blade and I see (hear) the problem with multiple blades. It whines before any thing touches the blade Sep 22 '19 at 19:46
My son had a Craftsman 10” saw that the shiv or pulley connection to the shaft was loose. It would spin up but was noisy and when he tried to cut the blade stopped. I checked it out and the set screw had backed off a bit and it did damage the shaft because he had tightened the belt and it worked for a while before he called. I tightened the set screw on the shaft the shaft to pulley or shiv is not perfect because of the spinning damage but with the screw tight it works fine.
  • Thanks. I found that the set screw is completely missing. Should be an cheap, easy fix. Sep 28 '19 at 15:06
  • I think my sons was a 1/4-20 if you take the pulley in any hardware or big box store should have them for about a buck.
    Sep 28 '19 at 15:11
