I bought London 3 light lamp and put 3 LED bulbs 6W. and doesn't work. Only when I switch on then flashed for second but only 3 times. Normal lamp works without problem. There is 2 cables. 1 cable to one bulb 💡 when connect only this cable lamp glow. When connect only second cable that connect 2 bulbs. Don't work. I was thinking tha lamp is faulty and bought another one but another lamp didn't work also. When I connected lamp to wall outlet lamp work perfectly. When I changed to normal bulbs lamp worked. When I have 2 terminal LED bulbs and 3rd middle one normal - lamp works. I need to add that lamp is connected to 2 way switch. That's very strange problem, maybe someone know the answer. Thanks Artur enter image description hereenter image description here
  • 5
    How exactly did you connect the wires when you tried multiple lamps? Series or parallel? Draw us a diagram of what you did. – brhans Sep 19 '19 at 11:20
  • What type of switch? Electronic switches not listed for use with led’s Sometimes do exactly what you describe. Getting a switch listed for use with LED’s will probably solve your problem. If properly wired. – Ed Beal Sep 19 '19 at 14:07
  • Were there LEDs in the previous light? – Harper - Reinstate Monica Sep 19 '19 at 16:27
  • I have a similar problem with an outdoor light. I think it simply does not work with LEDs (hard wired to power). It is a motion detection light though – Joe Phillips Oct 9 '19 at 18:07
