I ran into an issue when changing an outlet and switch in what I thought was a double gang box. After opening it up I found it was 2 single gang boxes next to each other. The previous switch and outlet (non-GFCI) fit in there fine so I thought no big deal and replaced them.
Well after replacing them I found that my wall plate is a ways off from being able to fit. Has anyone ran into an issue like this before? Is there a way to make this work? I would prefer to not have to cut them both out and put in a double gang if at all possible.
Thanks
