Is there an optimal distance from the pressure tank to install the Tee joining the line from the pump, line to the house and line to the pressure tank? We have a convertible jet pump with an injector bringing water from an 82 ft well. The line from the well comes up into the basement, the pump and pressure tank are within 8 feet of the well line. Currently the line comes out of the pump about 16" to a Tee with about a 24" line going to the pressure tank. All of this is at floor level with the house supply line running up the wall to the ceiling directly above. enter image description here
The optimal distance is as close to the house feed line as possible. But "less than optimal" may not be enough difference to notice, particularly if the tank tee line is adequately large diameter. Are you experiencing a problem related to the pressure tank?
I'd personally be penciling in "replace with a submersible pump" for future water system considerations. Jet pumps are a technology whose time has come and gone, IMHO. They waste a lot of power, for one thing.
  • Thanks. Just replaced the pump & pressure tank so hope we've got a while before we need to do that again. The new pressure tank is providing adequate pressure. We were in a rush so just put the new pump & tank into the existing hose & clamp plumbing last weekend but want to replumb it from the pump to the house water line. – SJP Sep 18 '19 at 1:22
  • Another question. We plan to plumb with 3/4" PEX. Can we use PEX from the Tee to the pressure tank? – SJP Sep 18 '19 at 5:22
  • A "standard" tank tee is usually at least 1" pipe, so using 3/4" for that is not great, IMHO. The idea is to minimize flow-related pressure drop (aka dynamic head) into and out of the tank. Such "standard" tank tees are easily available, typically with a union to make tank replacement easier. Unfortunate (unless there's some major issue getting power to the well) about the new jet pump. – Ecnerwal Sep 18 '19 at 16:02
