Bear with me. I am preparing for a future blackout. I did some research and am hiring an electrician. For my knowledge, could someone help me understand if i'm incorrect here.
I purchased 2 Pulsar PG4000ISR Inverter Generators hoping to run in parallel with interlock kit with inlet socket to power certain circuits in my house. Is this doable? Or would i be better off getting a generator with a 120/240v twist lock plug?
I do not have any 240v appliances in my house or would power. In this example would the Pulsar generators work as mentioned? In parallel it would supply around 6500 - 7000 watts on a single 30 amp breaker for me to divide amongst the main panel?
