Can holes in wood studs that previously held lag bolts be re-used with lag bolts of the same diameter or will this not hold safely?
More detail: I have a piece of fitness equipment mounted to wood studs in my garage. It needs to support ~350lbs of weight. The equipment needs to be removed and replaced. Can the replacement go back into the same holes or will new ones need to be drilled? I cannot use larger diameter lag bolts since they will not fit through the mounting holes on the fitness equipment.
Possibly irrelevant: It is a Rogue 3x3 Strip used to hold a Matador lite dip station. Since the load is very heavy, I used poplar boards as stringers to distribute the load across 3 studs. The strip has 4 holes for lag bolts so a total of 12 lag bolts were used. Unfortunately, one of the lag bolts broke off in the wall as it was being tightened. It was in the middle, directly anchoring the strip. In order to get it out, I'm pretty sure I need to remove everything to gain access to the hole and extract it.
