I have a garage which already has vinyl siding on it but the inside is unfinished and accessible. I would like to add an exterior wall lantern.
The vinyl mounting block I purchased looks like this and it is entirely hollow inside (does not contain any sort of structure behind what you see).
The light fixture I've purchased is just a standard wall lantern with a round base similar to this:
Patriot Lighting Brookline II
I would like help understanding which electrical junction box is needed behind this and how it should be installed. In order for the light to have any structure holding it up, I believe the junction box will need to be extend past the siding to the front surface of the mounting block. Is this correct? How do I approach this setup?
  • Is using a different mounting block an option? Sep 16, 2019 at 2:41
  • I think so. I was just trying to avoid taking the siding off Sep 16, 2019 at 12:05
  • Can you set your new box next to a stud and use a new construction box having it come flush with the siding? To me that sounds like the solution since you have access. If you want to put it in a space away from a stud scab in some framework to nail to.
    Sep 16, 2019 at 13:28
  • I can probably do that Ed. I'm not sure how to transition it from indoor to outdoor though. Just a small hole? Sep 16, 2019 at 13:30
Use a mounting block with a built-in box
The simplest solution to this problem is to use a siding mounting block with a builtin pancake box, such as an Arlington 8141 (the correct part number depends on the lap depth of your siding, the 8141 is what's used with a 1/2" lap) or equivalent.
  • 1/2" D4 siding in my case I think Sep 17, 2019 at 0:15
  • I bought a couple of these so I'll see how they work out Sep 20, 2019 at 0:33
  • These worked great, by the way Jul 5, 2022 at 18:05
