I've recently gotten a new flat, and the second room has fitted wardrobes along one wall (e.g second picture). I would like to put a TV and playstation in one of these as I don't need the storage space. However, the only accessible plugs are on the opposite wall of the room.
Along the opposite side-with the wardrobes- I do not know, but I suspect there could be a mains socket or several behind the wardrobes somewhere.
I would like to unscrew a fitted wardrobe from the wall (two screws along the top, below) to check for a plug, and if it is there, I will make a small hole in the back panel for mains access.
Can/Should I do this, would it be safe and will I be able to screw the wardrobe back into the wall (i.e through original holes)?
Alternatively, if you have a better suggestion for what I could do, I'm all ears.
