My home dates to the 1890s. It has clearly been through many renovations over the years before I owned it. The walls in my living room have defied all stud finders: normal ones find nothing, magnetic finders read the whole wall as a stud. Tonight I found this when removing a vent cover.
It looks like the wall is plaster over metal mesh. Can anyone give me any idea of when this construction was used? Is there anything special I need to know about? I'm just looking for information.
  • You need to revise ask about an actual problem you're facing. Finding out a date isn't a home improvement issue, and "anything I need to know about" is far too broad for our Q&A format. – isherwood Sep 13 '19 at 19:51
  • @isherwood perhaps the "real" question should be about the stud finders not working... – Solar Mike Sep 13 '19 at 21:02
  • In my experience the modern deepscan models do fairly well (outside the corner mesh zones, anyway). – isherwood Sep 13 '19 at 21:09
    My moms house is made with expanded metal mesh and a cement mortar both inside and out it was built in the early 40’s . I have remodeled several homes that were built after the 1906 earthquake in Northern California so in that area this was not unusual (north Bay Area). – Ed Beal Sep 13 '19 at 21:44
    In the UK, upwards of 1930. In the US, upwards of 1950. - In 1890 it would've been lath and plaster. This is the house's second set of walls, at least. - It's awesome stuff and it sucks to demo. – Mazura Feb 11 at 3:29
Plasterers used metal corners with wire mesh some 30 or 40 years ago before the plastic cr*p became popular (possibly cheaper, no corrosion issues etc).
How many years metal mesh was employed for is a question that may not be so easy to answer...
| improve this answer | |
    What plastic are you referring to? Metal corner bead is still the standard, and mesh has been replaced by paper tape, mostly. – isherwood Sep 13 '19 at 19:53
    @isherwood perhaps your locality differs from mine... perhaps the professionals / contractors are different... – Solar Mike Sep 13 '19 at 21:01
    I have the metal mesh corners in my 1956 house. What a pain to demo! – SteveSh Feb 11 at 0:10
