I am planning to install a large wooden work table in my basement. The top is 10 x 4 x 3" which means it will weigh about 500 pounds.
The problem is: how do I get it into the basement? The only access to the basement is down a flight of stairs. It is a straight shot, no turns, but I still need to get it down the stairs without damaging anything, so sliding is not a good idea.
Even with 4 men, each can only lift about 100 pounds, so that is not enough strength, and I don't see how I could get more than 4 men lifting the table. In fact, going down the stairs, it would be difficult to fit more than 2 men, one at either end.
