What is this next to the sink?!
    Can you add a picture showing any plumbing or fittings inside the cabinet?
    – Mobius
    Sep 9, 2019 at 18:45
It looks like my glass/ bottle washer. Is there a knob that turns the hot water on? Mine only had hot water ran the sink until hot set the glass on the wash push the button it would go for 20~ seconds great for rinsing home brew bottles out, those I had to hold the bottle in place because I lost the holder.
  • I believe all you have to do is to push down (upside down) on the glass and water will spray into it. You can rotate the glass on the black part while it is washing. You then put the glass (upside down) on the grate to let it drain.
    – Ron Beyer
    Sep 9, 2019 at 18:49
  • Mine the center spun it had a timer but it could be a press down to turn on. I had one originally that connected to the faucet but with this you could not wash anything else that’s why I added the fancy one.
    Sep 9, 2019 at 20:54
I do not think that it is technically a "washer".
It is more for rinsing a glass, by itself it is not enough to wash the glass.
These are used in bars for draft beer. If you rinse a pint/beer glass with cold water just before you fill it with draft beer it will prevent the the beer for foaming to much which will result in to big of a head on the beer.
As a lover of beer, i know this :)
Why you want to rinse your beer glass - "beers pour better in a wet glass"
It would be useful for rinsing any glass prior to its use to insure the dust and stuff that may collect in it is rinsed away before you fill it.
  • Thank you much! I appreciate the quick responses. Sep 9, 2019 at 21:37
I think Ed Beal in correct. Here is a picture of a different style one:
Here is a link to several variants if anyone is curious:
https://www.alibaba.com/showroom/pitcher-rinser.html
