There's a wall in my house that I'd like to open to widen a room. The beam (a single 6x10 of hard wood) above is sitting on the concrete foundation at each extremity of the house (10in wide concrete) and there's 3 steel columns that supports it. In between the steel columns, there's a wall made of 2x3s every 16 inches (some are doubled in the center).
|-----------------------------------|< 10in concrete
========O=========O=========O======== <- support beam (sits on concrete)
10in concrete                       10in concrete
O = position of the steel columns
Wall
I won't touch the 3 steel columns, they will remain where they are.
Can I remove those 2x3s?
EDIT: Photo of the top of the steel
Top of another column: enter image description here
  • you should be able to remove the wall ... i would be surprised if the top of the wall is even touching the steel beam
    – jsotola
    Sep 7, 2019 at 1:15
  • We can’t see the beam yiu say is supported by the jack posts. What size is that beam and what kind of beam is it? Does the wall attach to the beam?
    – Kris
    Sep 7, 2019 at 1:24
  • Yeah sorry the picture is bad, on top of the steel column there’s something that looks like a 2x6 or 2x8 then beam is sitting on it. It was like that when I bought the house. The beam is a single 6x10 of hard wood. Sep 7, 2019 at 2:14
Yes, you can remove the 2x3 stud wall.
There is 1) single top plate, 2) no plywood for shear wall construction, 3) no hold-downs for uplift or “racking” considerations, 4) the steel posts are close enough together to support 17 train locomotives (well, a significant load).
2x3’s are not used for structural walls.
Is that an adjustable cap on that steel post?
  • It’s a 2x6 or 2x8 then beam sits on it. The other 2 don’t have that and the beam sits directly on it. Not sure why this one has this (was like that when I bought). Sep 7, 2019 at 2:15
