I've been struggling getting a simple drip water system running.
I don't think the specific brand matter, but I'm using Rain Drip components from Lowe's.
I have 10 rose planters I'm trying to connect together. I'm using a faucet mounted timer/pressure regulator.
The system comprises of 1/4" tubing, with assorted outlets: drippers, "bubblers", sprays. I cut the tubing, insert barbed T-connectors, and then use short (3-4") tubes to reach the outlets. The last item in the chain is just connected straight to the tube. All of the tubes are the same (vs a 1/2" feeder to 1/4" branches).
I tried working with the drippers, but it was inconsistent. I've since switched to sprayers. These are small, adjustable sprayers and cast water out in 8 or 10 streams (vs a classic sprinkler head that actually sprays).
But, simply, I don't get consistent pressure across the system. The first sprayer is "ok", but the rest mostly just gurgle along regardless of how I adjust them.
I've tried removing the timer to use the full pressure of the house water, and it didn't make any difference.
This all seems just far too complicated for such a simple system. Cut the tube, plug in the fitting, move on. I don't believe it's clogged with anything but, honestly while the system is pretty trivial to put together, taking it apart is a real pain (most likely a feature, not a bug long term -- but short term, it's pain).
So, I feel like I must be missing something fundamental to these drip systems.
I guess what I should do next is go to each sprayer, remove the head, and turn it on and see if I get the same height from each one. But I can use any advice from folks with more experience with these systems.
