We have an extension on our 1950s house which looks like it was put in very early on, and it extends a single bedroom out into a master bedroom size room.
This extension has a pretty flat (it has a slight slant on it away from the house) roof, which connects to the main house underneath the current eave.
The structure of this roof is solid - I (a fairly substantial 40 year old man with too many pizzas under his belt) can walk on it without difficulty. The top surface is metal (type unknown).
This roof has developed a leak in heavy rain, which I have tracked down to one seal between two metal sheets - I have sealed it with spray sealant and this seems to have resolved the leak during our southern hemisphere winter rains. There is no obvious issue with the seal, ie no obvious hole or deficiency, but spraying this one particular area has prevented water ingress during several nasty and sustained rain storms over the past few months (the leak originally came to light during a fairly heavy storm overnight in the middle of last summer).
One of the two options for permanently resolving this issue (other than replacing the roof) is to use a liquid rubber product to coat the entire roof in a waterproof seal - it looks fairly easy to apply, is supposed to last a decade, and looks like it can be worked into small nooks and crannies to form a good seal and coat.
What are the downsides to using this sort of product?
A few I can think of include:
  • Its pretty permanent, replacing it later on probably means a more significant amount of work on the entire roof
  • It may cover up other issues
  • It may not work
  • Its another one of those "cheap options" (probably $100 for our roof) which makes me think I'm about to do something very very wrong
What am I missing?
  • So is the product UV resistant for 10 or 20 years? What happens as the metal expands / contracts - will it split over time?
    – Solar Mike
    Commented Sep 3, 2019 at 5:05
  • @SolarMike the product I am looking at has a suggested 10 year lifespan, and is designed specifically for the NZ market (so high UV, metal roofs), so I dont think it would have an issue with expansion and contraction - its aimed at both the DIY market and the professional market.
    – Moo
    Commented Sep 3, 2019 at 5:10
  • Add that info to your question properly - it is important information...
    – Solar Mike
    Commented Sep 3, 2019 at 5:12
  • Are the heads of the fasteners (usually screws) exposed on the roof or are they hidden under standing seams? Commented Sep 3, 2019 at 11:10
Adding a sealer to the surface does not sound like a permanent repair - may last a few seasons...
Covering the whole roof again does not sound like a reliable solution. Will this treatment do the 70years the original surface did?
I would look at opening that joint by removing the rivets / screws whatever the fixing is, then re-doing that seal and refixing the metal back down securely.
  • A metal roof is a slick surface which sheds leaves and other debris. If the roof is nearly flat like yours, it will not shed by gravity and rain, but it can be cleaned so dust will not build up to a crust. If you would cover the metal with rubber, then debris would collect, the metal would be kept wet for long periods and would corrode.. Commented Sep 3, 2019 at 11:00
  • See youtube.com/watch?v=G1UKZz6nJ-w Commented Sep 3, 2019 at 12:01
