Kitchen faucet was replaced...now it wont allow both Hot and Cold mix to flow together always shuts off.
Hello, and welcome to Home Improvement. We'll need more info to tell you, but it sounds like whoever replaced the faucet made a mistake. And, you should probably take our tour so you'll know how best to participate here.– Daniel GriscomSep 1, 2019 at 12:10
Will it work on both full hot only and full cold only?– Jim StewartSep 1, 2019 at 16:59
1 Answer
Look at and read the instruction sheet that is usually in the box with the new faucet. If it is a cartridge type , the cartridge may be installed in reverse or backwards.
