I'm attempting to replace a bathroom sink drain and figured this rubber flexible coupling would be a prime spot to disconnect the old. However the two clamps don't seem to have a slot for a screwdriver to undo/adjust.
Front: enter image description here Back (no the slight line is not an indentation for a screwdriver). enter image description here
Is there a special trick to adjust/loosen these clamps or will I just have to cut it off?
  • Looks like you need to use a socket wrench or regular wrench; have you tried that? – UnhandledExcepSean Aug 31 '19 at 17:10
  • @ UnhandledExcepSean You should type that in as an answer. – JACK Aug 31 '19 at 17:19
You can use a socket or regular wrench to turn those types of clamp screws.
| improve this answer | |
  • wow I didn't see the hex shape – depperm Aug 31 '19 at 17:35
