In the US, code dictates that the drain (p-trap and arm) on a shower use 2" pipe, while on a tub you use 1.5" pipe.
I understand that is code, but I am curious as to why it is the way it is. Sometimes code just is what it is, but I was wondering if there is a physics answer to this question. Is there a reason why a shower is larger from a performance perspective?
And, is there any harm in using a 2" drain pipe for the tub as well?
  • water gets sucked out of the tub by siphoning action ... the shower does not have enough flow to start siphoning
    – jsotola
    Commented Aug 31, 2019 at 6:05
Tubs are big and intend to hold the water; drainage speed is not really important. Showers on the other hand have a low curb and can’t hold much water, so it is important that there is plenty of drain availability to prevent overfilling and flooding.
Some tubs do have 2” wastes, but I think smaller drains are more common as it reduces the possibility of completely using downstream pipes via multiple upstream fixtures draining simultaneously.
  • That makes sense!
    – DA01
    Commented Aug 31, 2019 at 16:37
From a performance perspective a slow drain in a tub means it takes a long time to empty. Slow drains in a shower mean that the water can end up sloshing over the curb while the occupant is doing their hair belting out Van Halen's greatest hits. But I suspect the actual answer is that there are way more multi-head showers than multi-tap tubs.
Finding a 2" bath waste might be difficult. Technically you could use a standard one and increase the diameter between the waste and stack, but that would seem to have zero benefit for the overwhelming majority of cases.
    Also, showers do not have an overflow pipe, like tubs. +1 for good answer which includes VH reference. All my future answers will contain a VH reference, maybe hidden or only noticeable by true fan... Commented Aug 31, 2019 at 2:43
  • A very good point. In fact, our shower is going to be a double head shower. I hadn't considered that aspect.
    – DA01
