I don't think it's the best title, but I don't know what else to use.
I have several of these large tiles, and I want to make a planter out of them. Is there a bracket (like the image below) that I can put in each corner that will hold these five tiles together so that they stay together?
If not, how can I attach five tiles so that they stay together and remain together?
It will be used as a planter. The brackets could be on the inside or the outside.
    Epoxy and square wood blocks on the inside of the cube. Is that an option? – UnhandledExcepSean Aug 30 '19 at 20:31
  • @UnhandledExcepSean Or epoxy and metal brackets on the inside. But inside will hold and look better than outside. – manassehkatz-Moving 2 Codidact Aug 30 '19 at 20:35
  • @UnhandledExcepSean, that's a good idea, but it would have to be something that's not made out of wood. It will be used as a planter. – rbhat Aug 30 '19 at 20:48
  • Look at these. us.playwood.it – Alaska Man Aug 30 '19 at 20:54
  • What plant are you putting in it? What is your weight limit for the planter+soil? – UnhandledExcepSean Aug 30 '19 at 20:58
I would just buy some 2"x 3" or 3"x3" aluminum angle and cut off 2" pieces and drill holes in each side.
You could get a lot of brackets from a long piece of angle and epoxy them to the tiles. Aluminum is soft enough to cut with hacksaw .
You could use a diamond drill bit to drill the tiles and dill holes in the angle to attach the brackets with machine bolts.
OR
Look at these. Playwood
