I'm building a cat climbing wall, and plan to have a series of large "pegs" as steps. My plan is to use 1-foot lengths of landscape timber (basically a 4" diameter log) and attach directly to the wall studs using one 3/8" x 3" dowel screw for each peg. All shelf brackets I've seen have a lower support brace and more than one screw connecting to the wall, so I'm slightly concerned that one screw won't be enough to support the cantilevered weight of a cat (~15 pounds, plus dynamic forces). Is this realistic, or will the screw pull out, or will the log put too much pressure on the drywall, or any other reason why this would be a bad idea? Should I just put the screw off-center toward the top of each log so there's more of a lower brace, or use bigger dowel screws, or will I need a proper shelf bracket to support the peg?
1What's the diameter and length of the screws?– isherwoodAug 30, 2019 at 18:48
1Have you considered building a whole unit with all its steps and whatever else you want on sheet of 3/4 plywood and then just attach the plywood to the wall with screws into the studs. Sand and Paint it nice and neat and it can be removed or taken with you if you move to a new place.– Alaska ManAug 30, 2019 at 21:42
1 Answer
Assuming that:
- the screws are at least 1/4" in diameter
- they penetrate at least 1" into the stud
- the timber ends up snug to the drywall
... this should work fine. The key is that installation leaves the timbers with no gap to the drywall that would allow movement. If there's room for movement, the drywall will eventually be damaged and the screws could work loose.
Yes, it would do to install the dowel screws closer to the top of the timber, say 1" down, to reduce pressure on the lower edge of the cut. You might put waxed paper behind the timbers while you thread them in to act as a lubricant and to protect the wall.
You could simplify matters by installing each timber segment on a backer board (say a 16" segment of 1x6) using three or four 2-1/2" screws, then simply mount those to the studs over the drywall. The torque load on the timbers would be transferred to and distributed by the backer boards rather than through drywall, which is quite soft.
In the end, I went with the backer board solution, which is very sturdy. I was slightly concerned about the load distribution on the end of the timber alone, and I also couldn't figure out how I'd tweak the orientation of the timber when fully tightening it onto the dowel screw. Sep 15, 2019 at 4:36
