What can I do to keep this Gazebo from tipping when wind comes? The sticks that come with it to dig into the ground is not strong enough to hold it in place.
  • I see 4 legs either screw them to some decking or if in dirt use rebar driven at an angle away from the structure and attach a cable from the rebar to the leg above the flange.
    Aug 24, 2019 at 2:46
  • Yeah Ed , he's doing this in the ground. Much better if it were on a deck... Rebar's are the cheap quick and most effective way 💪👍 Aug 24, 2019 at 3:30
  • No offense but this looks like a hunk of junk. The manufacturer will probably get sued once someone gets hurt or stabbed by this. But they will be out of jurisdiction. My guess is about 120 on Amazon or alibaba. Anchoring this either involves welding or putting a big "hook over each of the bottom rails. Good luck.
    – DMoore
    Aug 24, 2019 at 6:06
  • 4 guy lines to decent pegs from the 4 top corners... But agree with the other comment about the design...
    – Solar Mike
    Aug 24, 2019 at 7:30
If the steel legs are hollow, you could possibly drive some steel rebar pieces vertically and get 4 people to help you set it down on the ground over the 4 exposed rebars.
Parts: 4 pieces of 6 foot long rebar's ( Home Depot /Lowe's sells 6ft length rebars.
Tools: Mini Sledge hammer
To do: Drive 4ea 6 ft rebar's into the ground 3-4ft deep
Theory: If this gazebo is sitting over 4 rebar's which are driven 3-4 ft. in the ground, and exposed 2-3 ft out of the ground, there's no way the wind is going to "knock it over.." And only you will know the secret.🙂
