I’m building a soundproof room in a garage for a friend, after having done something similar for myself, but am not sure about the ceiling. I was planning to use two layers of acoustic plasterboard (roughly 40kg per 2.4x1.2m), with rock wool in between the joists. The joists in the garage look like this:
joists
Would that be too much mass for the joists, or would it be okay?
    Hello, and welcome to Home Improvement. Without more info, the answer is going to be "it depends"; could you add a diagram, with the dimensions of the ceiling area to be soundproofed? And, you should probably take our tour so you'll know how best to participate here. Aug 24 '19 at 1:37
  • diy.stackexchange.com/a/146400/46271. Good related info
    – Kris
    Nov 12 '19 at 14:14
