I have a fully submerged water pump for my well which is 200 meters deep. The water pump is 3HP, and uses 15 Amps at 220V. Can this generator power the pump (I've provided a link below). In theory it should but I'd like to see if anybody has used it seeing as it's quite expensive.
Link to see info about the generator: http://www.kiporuk.co.uk/diesel-generator/kde-7500sta-diesel-generator-779-64-427.php
Edit: Somebody told me to use a startup capacitor. Would that help during the transition period?
