Water leak through vinyl and plywood on open deck, some locations already sunken due to rotten plywood underneath.
I would like to replace by MDO plywood (Crezon plywood) and then paint on top of the new plywood.
Can you suggest a type of sealant for the joints of each piece of 4' x 8' plywood?
Do you think this is the most economical way of replacing the deck material?
Our ambient temperature is between 30 degree to minus 10 degree Celsius.
    What problem are you trying to solve? The deck was originally covered in vinyl because you can't seal joints in plywood and expect it to remain water-tight. Wood moves, tearing seams loose. It just won't last, especially under foot traffic. If it did you wouldn't see asphalt shingles on roofs--you'd just see painted plywood.
    Aug 22, 2019 at 2:33
  • Duplicate: diy.stackexchange.com/questions/171777/…
    Aug 22, 2019 at 2:48
  • Open plywood? Leaking , a photo may be worth a 1000 words here. If I had only the info you’ll provide today I would use a membrane to seal the deck with a wear surface above that but this is just a comment because I am not sure of the construction, but the rot needs to be removed and repaired first.
    Aug 22, 2019 at 3:56
  • What every your soultion ends up being, make sure that the roof is not flat, even if it's flat and slanted. A slight dome shape will help keep it from developing a low spot that might trap water. Aug 22, 2019 at 16:17
  • The typical solution is to seal the roof (usually with a continuous heat-sealed membrane) and then build a floating deck on top of that using dimension lumber "joists" (often just 2x2s) that sit directly on the sealed roof, allowing for run-off. Care needs to be taken to match the load-bearing structures to the foundation. Unless done perfectly, it always leaks.
    – user101382
    Aug 22, 2019 at 20:14
This is not going to work. Plywood moves less than normal wood, but it still moves. It will be impossible to seal the joints between the sheets.
I would use ordinary plywood or chipboard, cover it with a waterproof membrane (probably EDPM), and then cover that with something else (stone chips, decking, whatever).
  • The material used to prevent snow dam damage above gutters would work. There's also heavier rubber/vinyl (?) material used to re-roof mobile homes that would be an excellent choice, but it's kind of pricy. As long as you aren't wearing cleats it's very good. Aug 22, 2019 at 16:16
  • @Ring Do you mean as an overall membrane, or as a seal over just the joints? Aug 23, 2019 at 8:47
    As an overall membrane. Only covering seams on plywood decks is a waste of time and money. I can't for the life of me remember what is was called. It was a roofing system I helped flog to mobile home owners as a telemarketer many, many years ago. It really was great stuff and I honestly would have sprung for it had I needed such a product. It was impressive. Aug 26, 2019 at 16:38
