Fixture has 3 hanging lights, each light has 1 green, 1 white and 1 black wire. There is also a bare copper wire on the base of the new fixture. How do i properly attach the green ground wires and the bare wire?
1Is there some reason that's making you believe that you can't simply wirenut all the ground wires you've identified to the ground wire(s) coming from the ceiling box? – ThreePhaseEel Aug 20 at 4:06
I was wondering the same, in the U.K.? Or some place home wiring not legal? – Ed Beal Aug 20 at 6:50
Use the screw in the bottom of the octagonal wire box on which the fixture is suspended. Use a small bit of bare copper to "pigtail" the three cables with a "marrette" wire nut, then attach that to the wire box. – Stavr00 Aug 20 at 13:02
